VCDS needed
After changing a split vac pipe on my inlet manifold i need to remove the engine management light and check to see what codes there is.so if there is any of you kind gents that live near doncaster and would be so kind to help me out im sure your beer tokens would be well earnt.Thanks in advance.
Check the VCDS owners "map" in the diagnostics section. :)
