Adjusting the hood.
I have just noticed my hood doesn't line up with fenders perfectly. Seems like hood sits a bit higher on one side, that results in slighlty wider gap between fender and hood on one side. Is there any way to adjust this?
Can you show it with piuctures, which would be most appreciated.
Should just be a case of adjusting the hinges (loosen nuts just enough so that you can move the bonnet (Hood) line it up and then re-tighten the nuts
