window motor regulator removal
Hi all,
following my previous post requesting info on door card removal I have finally found the time with decent weather to remove the door card, having been unable to find any damage to the wiring loom and managed to prove conductivity between the door connector and the motor plug in connectors I'm guessing that the window motor is at fault, I assume the motor is held in place by the 3 bolts once these are removed how do you remove the motor ??
thanks in advance regards Dave
Once you remove the three bolts it just pulls off.
