Failed MOT on emissions, booooo
DCF27FE7-E657-41C7-96F6-661EEEA8435A_zps
Going to try
Fuel additive
Clean MAF
Clean boost sensor
Clean K and N filter
New fuel filter
Italian tune up
Oh! and change an indicator bulb to. :)
And we will see...........
Edited by mluton
Do you have a leak in your exhaust, worth a check?
It looks like your CO reading is 3 times greater than the limit.  I can't say as to why as I am not really that familiar with the ins & outs of petrol engines.  Good luck with getting it sorted though.
First of all, I suspect that the car was not fully warm, hence the lambda fail on the first test. That aside, I would suspect the cat.
these are high values on the MOT file...even my car wich is euro2 rated passed the MOT with lower values.But  my car is 100% stock and the mot guy said it passed with great succes
I've done what I can, it's back on Wednesday so they can check the underside.
Unsure if I should undo the n249 bypass but I think I'm ok from what I've read.
I'm looking at Vagcom stuff but unsure on what I'm reading.
Edited by mluton
Just noticed last years MOT had an advisory for a minor front centre exhaust leak. Strange how is wasn't picked up this time with the same garage, but might be adding to my emissions issue.
Check breather hoses I had a split in one from the inlet manifold sent the fuel trims out enough to out on the engine warning light.
Did all them not so,long ago, but will take another look, Cheers.
Take it for an Italian tune up and make sure it's hot before the re-test
Just a thought, if the cat had failed, the engine should show a MIL light. These figures look suspiciously like a non-cat car. Has the cat been removed and the sensor deleted ?
No, original CAT still in place, But has a CAT back exhaust. EML is on because I removed the SAI relay because I have a leak, but have put the relay back in now.
Possibly bad pre cat lambda.
Edited by mluton
I will be, been driving it like a loon at high revs since.
i will pace it to the garage on wednesday and hopefully they will get it on whilst still hot.
Logged a few things on the way home from work and from the start i seen a problem. CTS reading was 15c and outside was 25c.
Temp gauge went to 90c and this is what i saw on my 20 mile journey home, never went above 74c.
And also driving keeping on boost today I noticed some nice exhaust pops. I have a few CTS's in the garage from when I was diagnosing CTS or thermostat at fault so I will swap it when cold and see if the readings are better in the morning and see if the exhaust pops are less or none existent.
Edited by mluton
A little bit off topic but does a eml make your car automatically fail its mot?
Nope just an advisory.
If all else fails maybe consider the terraclean process as that might clean enough crud out to get it through
What is a terraclean I'm intrigued?
Matt. Temp sensor on the blink could cause over fuelling. Should sit at around 87 until you hit traffic then can go up to around 115 before the dash gauge moves higher than 90.
HTH
David 8 have u used this service can vouch for the results? my cars just about to click over 170k with nearly a full service history but I've only owned it for about 4 months so can't comment on its past. It says it's a preventive measure so is it to late really for me to benefit in your opinion
Edited by Skodaphobe
Not me mate don't know much about it.
That reading does not seem right
It's not, thats the good thing.
Sent from my iPad using Tapatalk HD
Edited by mluton
Just had an idiot moment.
Went out to swap CTS, plugged in VAGCOM and outside temp matched reading for CTS. So I thought, time to swap.
Forgetting the CTS is reading 10-20c down and pulled out CTS, got a bit wet, as still very warm and under pressure.
Bonus is the other sensor I have is reading outside temp ok.
Try again in the morning.
