1.2 Tsi CAM drive
An engineer checked out my week 22 (27/05/14) built Yeti and confirmed it has a chain driven cam.
It must be chain if the cover is aluminium as opposed to a 'ventilated' (non-sealed) plastic one.
The cover was black plastic.
So I wonder how they seal the oil in.
Yes, but they can do wonders with plaskit these days...I am though going to investigate this further. I took it their expert would/should know.
To me at least, it would be a first.
The cover over the oil filter element is plastic....that seems to do a good job of sealing oil in :)
Skoda UK CS say it is a chain.
You can see a cam belt, you can't see a chain.
Never seen or heard of a plastic chain cover.
To me it's a first if true.
The oil filter top is threaded and has a rubber "O" ring seal, so not flat surfaces as the timing chain cover would be.
I thought VW had an issue with the chain stretching which they resolved with a belt.
I thought all their engines were belt driven cams.
