Engine management light
Hi guys,
Have fitted an egr delete and still getting the management light come on, checked with a fault code reader and it says it was egr out of value /range..      which I cannot understand as I have took it away. It is a 53 plate so thought it didn't need a re-map.  any ideas?
The egr valve needs mapping out as the ecu is expecting it to still be there and therefore isn't getting the readings it expects hence the engine light
  • 4 weeks later...
Any recomendations for people to map out the egr engine warning light in North West?
