I am having a problem with my fabia
Hi to all
I am having a problem with skoda fabia 2007 1.4 diesel
The power steering doesnot work , the abs doesnot work , the center lock doesnot work , I pulled the codes out
VCDS-Lite Version: Release 1.2
Saturday, 05 July 2014, 13:36:08:0
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine       Labels: 045-906-019-AMF.LBL
   Controller: 045 906 019 CE
   Component: 1,4l R3 EDC G000SG  9746
   Coding: 00005
   Shop #: WSC 13765
   VCID: 5AC7116BD507
   TMBBE65JX83080688     SKZ7Z0G4549901
4 Faults Found:
17911 -  Load Signal from Alternator Term. DF: Implausible Signal
            P1503 - 35-10 -   - - Intermittent
18263 -  Powertrain Data Bus: Software Version Monitoring
            P1855 - 35-10 -   - - Intermittent
18097 -  Powertrain Data Bus: Implausible Message from Elect. Load Controller
            P1689 - 35-00 -   -
18057 -  Powertrain Data Bus: Missing Message from ABS Controller
            P1649 - 35-00 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: Redir Fail!
   Controller: 6R0 907 379 E
   Component: ESP 8.0 front   H05 0002
   Coding: 0002377
   Shop #: WSC 13765
   VCID: 40F3C303539B
3 Faults Found:
18265 -  Load Signal: Error Message from ECU
            P1857 - 000 -   - - Intermittent
00532 -  Supply Voltage B+
            002 -  Lower Limit Exceeded - Intermittent
01314 -  Engine Control Module
            013 -  Check DTC Memory - Intermittent
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
   Controller: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E0FBDFB296F
5 Faults Found:
01316 -  ABS Control Module
            49-10 -  No Communications - Intermittent
01330 -  Central Control Module for Central Convenience (J393)
            49-00 -  No Communications
01598 -  Drive Battery Voltage
            27-10 -  Implausible Signal - Intermittent
01309 -  Power Steering Control Module (J500)
            07-10 -  Signal too Low - Intermittent
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 605 F
   Component: QA AIRBAG VW61 Q5Q6 0004
   Coding: 20801
   Shop #: WSC 13765
   VCID: 2721789FD6F5
1 Fault Found:
Address 17: Instruments       Labels: None
   Controller: 5J0 920 810 C
   Component: KOMBIINSTR.    V2823466
   Coding: 19113
   Shop #: WSC 13765
   VCID: 263F759BD1FF
3 Faults Found:
00779 -  Outside Air Temp Sensor (G17)
            30-00 -  Open or Short to Plus
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Component: 000E GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: F093D3C3A3BB
3 Faults Found:
Address 25: Immobilizer       Labels: None
   Component: IMMOBILIZER    V2823466
   Coding: 19113
   Shop #: WSC 13765
   VCID: 263F759BD1FF
No fault code found.
Address 44: Steering Assist       Labels: None
   Controller: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10140
   Shop #: WSC 00788
   VCID: 6F9150BF3E85
Address 56: Radio       Labels: None
   Controller: 5J0 035 161
   Component: Radio FO3       010 0029
   Coding: 0000200
   Shop #: WSC 13765
   VCID: DFB1A07F4E25
2 Faults Found:
00856 -  Radio Antenna
            011 -  Open Circuit - Intermittent
00668 -  Supply Voltage Terminal 30
any solution for these problems ?
thank to all :)
moved to fabia 1 section
That sounds like a low on juice battery to me!! Get it off and put on charge that should sort it!
