VAGCOM errors
Hello all,
The last few weeks I've had the fan kick in for no reason, normally of shorter journeys so I'd thought I'd give it a quick scan with VCDS. It came up with the two following errors on the engine.
Car is a Octavia vRS 2.0CR 2009 DSG
Tuesday,08,July,2014,18:12:55:51990
VCDS Version: Release 12.12.2 (x64)
                Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 RE    HW: 03L 906 022 GA
  Component and/or Version: R4 2,0L EDC G000AG  5752
           Software Coding: 0001078
            Work Shop Code: WSC 73430 790 00000
                      VCID:
2 Faults Found:
009754 - Coolant Pump 2
               P261A - 000 - Open circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 10
                    Reset counter: 255
                    Mileage: 51395 km
                    Time Indication: 0
                    Date: 2052.14.08
                    Time: 19:09:15
             Freeze Frame:
                    RPM: 920 /min
                    Speed: 0.0 km/h
                    Voltage: 11.93 V
                    Lambda: 79.7 %
                    Bin. Bits: 10010001
                    Bin. Bits: 00000000
                    Temperature: 13.5°C
000000 - SAE - Reserved by Document ISO 15031-6
               P0000 - 000 - 2005 - Intermittent
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 51510 km
                    Time Indication: 0
                    Date: 2052.14.16
                    Time: 19:56:48
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.70 V
                    Voltage: 11.70 V
                    Voltage: 11.70 V
                    Voltage: 11.70 V
Readiness: 0 0 0 0 0
From searching the first code is relating to the water pump which could mean it needs replacing, the other from google search comes back with DPF related, most common is related to cars that have be de-DPF'd.
Any ideas.........and is it going to hurt my wallet?
Mike
I had the same error code, rechecked it a week later and the error hadn't re-occured. Might be worth clearing the errors and re-scanning just to make sure.
Those are very low battery readings, ie 11.93V and 11.70V.
Cheers Chris, I will have a look at the suggestions on the link.
Structures, I've cleared them down and will re-scan later in the week and see if they have disappeared.
Dennis, maybe its time for a new battery, it's the original battery so over 4 years old and sits most of the week on the drive.
