Panel Filters
Has anyone been advised to fit a performance panel air filter while at or before visting Jabba ?
Pete red VRS
Pete,
it's probably better to have a high flow filter fitted before a remap however, I can't remember anyone who has fitted a panel filter. Most who have changed have fitted CAI (cold air induction) kits and will need removal of standard airbox.
If you decide to fit an panel filter avoid a K&N as these have been know to contribute to MAF (mass air flow sensor) failures due to gunking up with oil. Expensive to fix.
Check out CAI thread for more details.
Cheers.
Adrian.
According to Mike & Elton @ Jabba -- the standard set-up is fine -- only real improvement via Cai - as Adrian said.
Certainly happy with mine on standard filter - after remap - see signature :D
If you decide to fit a panel filter add to the airbox a decent sized and located cold air feed pipe.
