help please with new maxidot to my o2 restyling
hi all, I bought a maxidot in skodateile and i go to skoda to put, but they can not do it, fails, and says faz1220e error, serial number Elv VD1-XXXXXXXX is not new
what happend? what solution?
where are you located?
in spain
ok, a bit far away for me to help with fitting
How about some info on your car (old cluster part number) year
and part number of the new cluster
hello mi cluster actual is 1z0920843d (2009) and the new is the 1z0920843g (2010)
is it a pre-facelift to a facelift?
dealer doing the job?
facelift, and yes i go to skoda to install the maxidot
there is your problem
you need to read immo data from existing cluster
manually transfer that to the new cluster, then adapt 2x new keys
how can transfer manualy to the new cluster?
can use my vagcom to read immo? i have vagcom 12.12 rosstech.
in dealer skoda use vas 5051b  and cant install the new
Edited by kelgonar
Vagcom / VCDS can't retrieve all the immobiliser data you need to swap the clusters. The tool that you need and that I think Eddie uses is VAG Commander which isn't cheap - I think it is in the region of £1000.
I'm sure Eddie will confirm for you.
sorry my cluster actual is 1z0920803d and the new maxidot is 1z0920843g
post a pic up
what is a pic up?
VAS will do it, too.
hello today i was talking with oficial skoda service and say me that they have ask to skoda spain, and they say that same cluster are preprogram to same types vehicules, and probably our problema is this, because when connect the cluster to skoda system "vas", it say that this have a serial number not new, then this cluster are programmed for a one type vehicule, and this type not is my car. i need a cluster with serial number new or with serial number valid for my car, to connect in my car , the skoda system detect that this cluster is not valid for my car, due his serial number, because my car dont have this cluster in their database, i have minidot..
Edited by kelgonar
It won't
Cluster has to be new, and Skoda dealer needs to be connected to factory online
¿ how i can made the clustar new? skodateile.cz say me that the cluster is new, but it isn´t new. or the cluster is new but has associated other vehicle.
Edited by kelgonar
i have fitted several clusters that have come from skodateile and all have been new.
I'm guessing the dealers have screwed up and can't correct what they have done
** Listen to Eddie- NL **** he is the expert in this area and I wholly recommend him. He fitted my replacement cluster, MFSW, slip ring and Bluetooth. He also helped me out sourcing the replacement cluster swap to upgrade to MAXIDOT. He will fit on site if you are prepared to travel to him.
Eddie-NL- thanks again everything still working great and made such a difference to the overall comfort of the car !
Eddie-NL where do you live i need you¡¡¡¡¡¡¡ come to spain , to the beach ;))))) Today say me one persona that if i pay it 400euros he can install maxidot, , i cant pay this¡¡¡¡¡¡¡¡
can i send you my cluster maxidot and can you prepárate it for my car? i pay you Eddie-NL.
can i do anything with carprog ???
