Rev limit
Just curious
I know when you have a remap some companies raise the rev limit by 200rpm but can the 1.8T actually go higher?
Been watching some 1.8T related video's, mostly from europe where the needle is way past the end of the rev counter lol
The limiting factor is the hydraulic lifters, if you go to high then the valves cannot keep up and get smashed by the pistons. Usually going higher means serious upgrades to the cylinder head. Dont forget the "Maximum engine revs exceeded" fault code as well.
Yes you can increase
All down to turbo aswell if small turbo it's dead at 6k no point reving past that
Big big turbo you need to rev to 8+ k as that's the power band
Hydro can rev to 8.5 without issue
The issue is the valve springs need exhaust side upgrading to stop float
Valves are fine aslong as the guides are new
The ones ive seen are the supercar eating S3's
I imagine a slight higher RPM would increase top speed slighty although not much use in the uk tbh
Not much point if maximum bhp is at lower rpm
