Glow plug faults on 2.0 TDI VRS (07)
Hi all, I been reading a lot about glow plug faults( engine light on), but till today I haven't found a solution.
I already changed wiring harness, glow plugs and glow plug control unit (038907281D), but faults still pop up.
here is log from VCDS
4 Faults Found:
001649 - Cylinder 1 Glow Plug Circuit (Q10)
               P0671 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Status: 01010001
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 122600 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:18:23
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.75 V
                    Bin. Bits: 00110000
                    Temperature: 15.0°C
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 122600 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:18:23
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.75 V
                    Bin. Bits: 00110000
                    Temperature: 15.0°C
001651 - Cylinder 3 Glow Plug Circuit (Q12)
               P0673 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 122600 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:18:23
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.75 V
                    Bin. Bits: 00110000
                    Temperature: 15.0°C
001652 - Cylinder 4 Glow Plug Circuit (Q13)
               P0674 - 006 - Electrical Fault
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 40
                    Mileage: 122600 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:18:23
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                        0.00 %
                    Voltage: 11.75 V
                    Bin. Bits: 00110000
                    Temperature: 15.0°C
Can anyone advise me, what else can i check?
thank you
I have the same issue with 2010 skoda laura 1.9 pd with just 16000 kms. The dealer first changed the radiator fan which cost me a lot but wasn't solved, now it's been there for more than a week without any results. Am wondering if your car has hiccups when accelerating hard?
No I don't have problems with hiccups when accelerating.
