Central locking headache
Afternoon all.
Recently purchased an 07 vrs estate, love the car and have needed another vrs since selling the Fabia a few yeas ago!
Aquired this for a song, knowing that it needed a gearbox. Upon removal of the old box, noticed the clutch and flywheel were shot so replaced those too.
Now my problem is that it won't lock on the remote, but will lock on the button in the centre console. It won't unlock on either, the boot won't open from the outside unless it isn't fully shut, then it will allow you to open it to shut it if that makes sense so I know the boot switch is ok. The electric windows and electric mirrors work fine. When you unlock the car with the key, only the driver side door unlocks and 9 times out of ten will set the alarm off. If you hold the key in the unlock position it will drop the windows, and likewise when locking it will close them.
I've checked the basics, replaced the key remote as this was missing and all fuses seem to be intact.
Any help or advice is greatly appreciated, I'm wiling to cross someone's palm with shiny coin if a diagnostic plug in points me in the right direction!
I think a scan with vcds is definitely needed to see what's going on. It would help if you posted your location if anyone nearby can help. Or look in the vcds owners map in the diagnostics section of the forum.
Re only the driver door unlocking, there is a coding option that can be set where a single press only unlocks the drivers door and you need to do a double press to unlock all doors
Thanks, I live in Birmingham.
The remote doesn't work at all, I can only unlock with the key blade in the drivers door barrel,and then it won't open all doors, only the drivers one
Maybe possible bad Comfort module (behins glovebox) or problem with central electronic lock in drivers door (known problematic microswitch fault)....
Two things spring to mind:
1) (and they are oldies, but goodies) Does the red light come on when you press a fob button? Have you replaced the fob battery? Have you tried cleaning the contacts in the fob?
I was having intermittent problems with one of my fobs, popped it open, cleaned the contacts, now it works first time every time again.
2) Have you tried re-synching the key?
I follow this to re-synch on my last Octy:  (From a quick search on the forum)
1. I put the key into the driver's door keyhole.
2. Pressed the unlock button.
3. Turned the key to unlock the car.
4. Remote lock and unlock worked once more :)
The driver's door only (un)locking is a setting either in MaxiDot or within VCDS.
Thanks for the replies, the battery was missing from the key when I got it. I have now replaced the battery and the light on the key works so will try the sync thing this morning and let you know.
Tried the key sync but still no good. May need to search for a member local with vcds and get it scanned.
if you tell us where you are it may help us point you in the right direction
Hi I'm in Birmingham, it's being plugged in on Saturday so I should have an indication by then. I'll report back when I know more!
ok, i'm going to be in the Midlands at some point over the next couple of weeks so if the remote hasn't been sorted i may be able to help out. I have all sorts of VAG equipment & i'm also a mobile Autolocksmith & forum sponsor
Nice one thanks for the heads up
no worries! if you didn't get anything sorted i'm in Birmingham this Saturday 23rd
Diagnosis is ccm. Keeping my eyes peeled for a second hand unit!
if you know the part number there's always plenty on Ebay
Is it a case of plug and play, or will it need coding to the car?
it depends what exact car the replacement has come from. The same part number CCM is used in various models. Some are 2 door & some are 4 door etc. So you may get 1 from a 2 door in which case if yours is a 4 door you would need to change the coding with VCDS, which is easy. You will also have to code the remote in as well, again very easy with VCDS
