Vagcom help
Hi tried searches but cannot find anything, my mate has vagcom and I've been told there's a few bits you can add to your fabia I was just wondering how you get on them? Or what channels? I've heard you can set it to make a bleep when you lock and unlock and also been told when you turn the ignition you can get the dial needles to sweep all the way round and back again?
You can customize the steering sensitivity, activate the auto doors lock (>10mph) and auto doors unlock (when removing the key from the ignition), you can also enable/disable the selective door unlocking and of course, lock/unlock beeps using a VAGCOM interface. Unfornately, needle sweep, as well as the follow me home or cornering lights, I don't think are available for this car.
https://www.dropbox.com/s/2wshbr6bioxr60o/vag%20com%20octy1%2Cfabia%2C%20superb.doc
Needle sweep not possible on the Fabia 1.
All the channels that are available are in VCDS itself in a drop down box.
