Radiator fan bolts?
Just changed the radiator fan (non ac single fan type) on my fabia and the bottom bolt that holds the plug to the radiator sheared because it was just rusted and old. I'm a little worried about it rattling around and knackering my radiator, does anyone know what the bolts are called/where to get them from? They're the long torx headed ones with a plastic cap with an 8mm nut on the other end.
It the bolt you want on here?
Nope, although thinking about it, I could probably just use any old nut and bolt with a washer so as not to damage the radiator fins...
