interior light
At night when driving with the lights and wipers on the interior light flashes. has anyone else had this and how was it cured
thanks sam
Have you got LEDs??
yep they are led
canbus error free leds should sort it.
Your problem is that the leds are activating on so little power. So little infact that a normal bulb wouldnt react.
Canbus bulbs have resistors built in so should sort your problem. failing that, if you wanted to you could add resistors to your current LEDs.
i have read about that before and they are canbus leds and have been fine for around 2 years .... its only started recently flashing
