Rear wiper washer jet
Mines stopped workin ages ago does it run from the front bottle ?
Simon
Could be that the pipe has become disconnected (usual place is below the CD changer in the boot) - will get around to doing mine one of these days  :D
Ive got a cd changer?? Were should that be mike?
Left hand site of the boot in the wheel well, can't miss it! :)
Pipe for the rear washer jet is in the middle of the wiring loom normally and there is a joint in there that can pop when it's forzen or blocked - seems strange that you don't have a CD changer - all the Occy's I've seen have them fastened to the side of the metalwork behind the trim on the left hand side of the car
Not mine were the carpet is perforated that side its not been broken maybe the 1st owner had the 5th alloy instead??
Ok found pipe it was disconected so popped it back together to see if it worked
Hmmmm dont think it was the problem lol
There is another connector at the back of the washer bottle. If that becomes disconnected your car makes a puddle every time you try to use the rear washer. You can reach it without removing anything if you don't have massive hands.
Mine popped off at the join underneath the scuttle panel bottom of the windscreen. Check there too.
Second thoughts those pipes just do the front ones!!
