Dance radio coding for AUX
Hello!
It appears that some time in the history of my Octavia the Stream has been changed for a Dance headunit. It has 3 pins for AUX in the back but they were not connected. I have connected a 3.5mm plug to them but am not able to change the input. I have tried pressing CD button and looked through the menus but there is no sign of AUX anywhere.
Maybe someone who has a Dance unit with AUX could share his coding.
The current VCDS (has not info on that unit) coding is as follows:
Thursday,21,August,2014,14:05:29:62939
VCDS Version: Release 12.12.0 (x64)
                Address 56: Radio
Control Module Part Number: 1Z0 057 186
  Component and/or Version: Radio         008 0022
           Software Coding: 00000400000100
            Work Shop Code: WSC 52203
Advanced Identification
     Serial number: SKZAZ4K1700947
     Identification: YD5-001
     Revision: R0008000
     Date: 09.08.10
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Attempts(data): 0
     Successful Attempts(data): 0
     Programming Status: 00000000
     Flash Date: 0000.00.00
     Flash Tool Code: 00000 000 00000
     Flash Tool Code(data): 00000 000 00000
Misc.
     Hardware number: 1Z0 057 186
     Workshop System Name: J503
     Equipment/PR Code: 0000000000000000
VCDS Info:
       Labels: None
Thanks!
You need to enable aux first if I recall actually on the head unit. My Stream didn't have the option for Aux so I enabled it actually on the head unit. There is a YouTube video on how to convert the Stream to have an Aux in.
However I'm not sure if it's the same for the dance
Edited by MrTickle
I have attached the wiring just as described in the video. However, when I press the menu button as described in Stream and Dance manuals to enable the AUX only things that are shown are:
Learn: on               blank
Reg   : on              AF: on
Seek : dx               >  (to next page)
Pdc    : on            blank
Beep  : on            Illum: 2
Phone: on            Back...
It should be somewhere there I assume. However, the fact that it is not lead me to believe that the fault is in coding.
I'm not sure that the Dance has an Aux capability you know
