Timing
Hi guys just a quick one am I on the right group to check timing 36c129c1210e29adfffbe6ad54466fc9.jpg
Sorry for the crap photo
And what's it all mean lol Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NF
Component: 1,9l R4 EDC G000SG 5839
Coding: 00102
Shop #: WSC 13765
VCID: 68DF688A08E4595E337-4AE8
TMBWU46YX54256665 SKZ7Z0D2768986
3 Faults Found:
18097 - Powertrain Data Bus
P1689 - 35-10 - Implausible Message from Elect. Load Controller - Intermittent
19463 - Camshaft Position Sensor (G40)
P3007 - 35-10 - No Signal - Intermittent
19586 - EGR System
P3130 - 35-10 - Regulation Range Exceeded - Intermittent
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ASR80.lbl
Part No SW: 6Q0 907 379 AB HW: 6Q0 907 379 AB
Component: MABS 8.0 front H03 0001
Revision: 00000000 Serial number: 00000000000000
Coding: 0000008
Shop #: WSC 13765 000 00000
VCID: 7DF129DE2766ECF6F01-5140
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 250540 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F2EB8AE2BE38238E1D3-5140
2 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 25754
Shop #: WSC 13765
VCID: 3C77E4DA2CFC25FE87F-5140
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 11 AIRBAG VW51 0008
Coding: 12593
Shop #: WSC 13765
VCID: 1E330E529A2057EE89B-5140
No fault code found.
Address 17: Instruments Labels: 6Y0-920-xx0-17.lbl
Part No: 6Y0 920 971 S
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 28401
Shop #: WSC 13765
VCID: 4E93BE128A40A76E59B-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 003D GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
VCID: F0EF80EAB034119EEB7-5140
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10120
Shop #: WSC 13765
VCID: 6FED03962D0A8E6672D-5122
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 2Y Komfortgerát 0002
Coding: 00018
Shop #: WSC 13765
VCID: 3D71E9DE37E62CF6B01-4AE8
End ---------------------------------------------------------------------
AFTER
Saturday,30,August,2014,14:48:03:38786
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: TMBWU46YX54256665 License Plate: FV54NHF
Mileage: 251090km-156020mi Repair Order:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBWU46YX54256665 Mileage: 251090km/156020miles
Coding: 00102
Shop #: WSC 13765
VCID: 68DF688A08E4595E337-4B00
Readiness: 0 0 1 1 1
Coding: 0000008
VCID: 7DF129DE2766ECF6F01-5122
1 Fault Found:
Anyone
