Enabling rear DRL's with vcds on Octy MKII FL
Rear DRL?
You mean US mode?
Not sure if this is US mode. What I would like to enable on the MKII FL OCTY is the rear side lights to be on as daytime running lights. I know this can be done with the dealer VAS tool. It is also compulsory in Ireland.
I had it done on my MKII Vrs. Dealer only
On the pre fl it was US, and they come on only when the handbrake is off.
Or I think there's an option to enable side lights at all times which should work on the FL
It can be done by dealer (usually they charge one hour of diagnostics). I was also looking for this and yes it is Byte 18 issue. But sadly there is no experience what should be done.
Octy PRE-FL and AFTER FL have totally different settings regarding DRL, so US mode is out of option on FL.
Here exactly opposite was done on Golf 6. Maybe this can help:
http://forums.ross-tech.com/showthread.php?995-Disabling-tail-lights-with-DRL-s
Edited by mtl
