Eibach Lowering Springs
Ant,
"Hi the correct Eibach spring code for the vRS diesel estate is E10-79-010-02-22"
I'm collecting my new diesel vRS estate from Simpsons on March 1st or 2nd, so wondered whether you could fit the above spring kit on the way home?
Cheers,
Paul
  • Replies 60
  • Views 15.5k
  • I'll try to clear this up for you guys:   Octavia 3 Hatch:   1.6tdi, 1.8tsi, 2.0 TDI - E10-79-010-02-22 (30-40mm/30mm) - 1075kg rear axle 1.6tdi, 1.8tsi, 2.0tdi - E10-79-010-04-22 - 1030kg rear a
  • Clear as mud this thread lol
  • Mine was completed today at Skoda Preston. It's only when I look at these two pictures do you realise just how high the vRS sits out of the box. Far happier now. Before After
I will be now buying the eibach pro kit rather than the H&R as I don't want to much of a drop
Yeah, same here - I had a some Eibach that dropped my Saab front way too much and the result was that what was already a low spoiler lip became borderline unusable - It was scrapping everywhere and I had to stop using a certain undergroung parking because it simply would not go without scrapping
  • 4 weeks later...
Question for anyone with the E10-79-010-02-22 springs - are they black or red?
@Moley - you've had those on for  year or more now?  How are the dampers holding up?
Having mine fitted in the morning so can let you know.
They are black.
We just fitted Paul's springs to his VRS diesel estate. They drop the front quite nicely
They are black.We just fitted Paul's springs to his VRS diesel estate. They drop the front quite nicely
Can we get some pics?
And also, this is my experience with Eibach on the Saab: massive top on front, but rear too high...
Springs are black and yes the dampers are doing ok
Does putting the springs on stock dampers bugger them quickly or is it fine to do this? What is a good "off-the-shelf" combination of springs and dampers that ppl use or suggest?
My last two cars (both vRS) had Eibach's fitted with stock dampers. First one covered 108,000 with no issues and I'm on nearly 40k with the current vRS with no issues.
Stock shocks will be fine on a small drop in height. Usually the shocks wear quicker/fail usually more than 30mm drop
