Issues with Retrofit MFSW
Hi,
I hope somebody has a tip for me so i can solve this issues =)
                Address 16: Steering wheel       Labels: 5K0-953-569.clb
Control Module Part Number: 5K0 953 501 AT    HW: 5K0 953 569 H
3 Faults Found:
0516 - Databus
          U1121 00 [009] - Missing Message
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 125
                    Mileage: 52033 km
                    Date: 2036.14.27
                    Time: 22:56:54
335876 - Powertrain Databus
          U0002 00 [009] - No Communications
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 52033 km
                    Date: 2036.14.27
                    Time: 22:56:54
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 52033 km
                    Date: 2036.14.27
                    Time: 22:56:54
Your coding is wrong
What changes have you made to the vehicle to generate these faults?
What vehicle are you in?
What doesn't work?
Have you cleared the faults to see if they return?
Have you looked up the fault codes on the Ross Tech wiki?
Have you calibrated the steering wheel angle sensor according to the instructions on the Ross Tech Wiki?
A little more information given to us may help us help you with resolving this...
Code out the steering angle sensor (newer cars don't have this at the steering wheel)
That should sort it
Hi,
Its a Skoda octavia 2012 4x4 TDI
I have changed to the following items
http://skodateile.cz/index.php?pg=product∏=408&menu=%C5%A0koda|Octavia%20II%28A5%29%20facelift|Volanty
http://skodateile.cz/index.php?pg=product∏=252&menu=%C5%A0koda|Octavia%20II%28A5%29%20facelift|Volanty
There is no other fault codes, i have coded the steering wheel angle in module 44 and in ABS 03
What to do?
What doesn't work?
I have don ervery thing here http://wiki.ross-tech.com/wiki/index.php/Skoda_Octavia_%281Z%29_Steering_Assist
Edited by larserik
Whats wrong with it then?
That should sort it
how to?    =)
You use vag com
You use vag com
ross-tech vag com yes
VCDS
Edited by larserik
look in what you have fitted, the answer is there
module 16
coding
long coding
steering angle untick it
module 16
coding
long coding
thanks =)
thanks =)
Might this fix this as-well? 0516 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 125
                    Mileage: 52033 km
                    Date: 2036.14.27
                    Time: 22:56:54
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 52033 km
                    Date: 2036.14.27
                    Time: 22:56:54
try it and find out
Hi,
thanks for the help so far..
im still getting one fault.. 2 out of 3 is gon =)
  Component and/or Version: LENKS.MODUL   014 0140
           Software Coding: 1892140002
Fault Codes have been Erased
1 Fault Found:
0516 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 127
                    Mileage: 52066 km
                    Date: 2014.09.11
                    Time: 19:53:11
what airbag loom have you fitted?
  • 2 years later...
Good Evening Gents,
Apologies if I am in the wrong section. (new to this)
I am having a few issues with my Skoda Octavia 2013 1.6 diesel.
occasionally I have an issue with the steering, the red steering light comes up and I find the steering goes heavy and loses the power steering. after sometime the lights goes yellow then goes off and the steering is fine.
After checking with my trusty VAG garage have found it comes up with Code 294 B1168 Steering Angle Sensor too Low and also 12900H/76032 undocumented code.
After much despair booked my car in my local (dare I say it) main dealer. upon diagnosis they have told me that I would need to replace the steering angle sensor at a cost of £1500. also once they fit this part then they will see if there are any other issues (this of course would cost me more money).
also get the codes:
B1168F2 - Steering wheel angle sensor, No initialisation.
B200FF0 - Internal Failure
B20000 - ECU Internal Failure
please can someone help....
Gary
