Control Module
Hi
Can anyone help is there a wiring diagram anywhere for the control module?
Need to get a guy to look at this to see if the problem is external or internal on the module.
No electrical windows, no central locking, no interior lights and saying drivers door open and beeping too.
Gone on for ages giving up hope now.
cheers
dave
There's one at the back of the haynes manual.
How are you getting into the car with no central locking?
Are you saying that it is or it isn't beeping?
Are you talking about the beep when you leave your lights on?
How far have you checked into this so far?, have you actually removed the connector from the drivers door control unit yet?. this sounds like you may have a case of eroded pins on the module. you may also have a fault on the door lock which is causing the door open due to a microswitch error. Both these faults are known on here.
To be honest, I would check the control unit first as it seems as these cars get older this fault is becoming more prevalent.
On the subject of a loom diagram, as has been mentioned, there is one at the back of Haynes manuals, but it is not complete, and you would be better renting some time on erwin (elsawin and erwin are vag official service manuals) and printing what you need from there,
I take it you have checked the fuses to these units first?.
The CCM are known to get a bit damp sometimes.
