Too Pricey ?
Quote for fitting Cruise control to my Octy £175 + VAT (I will supply stalk) + £75 + VAT to fit DRL's (I will supply DRL's).
Seem too pricey ?
£175 in labour just for a stalk? Yes, that is too much. It's a job you can do yourself - but you need VCDS to code the car.
Fitting CC takes under an hour (plus leaving it to sit after disconnecting the battery, before fiddling with the airbag). So £175 labour seems very steep.
It's the airbag that's putting me off !!
Disconnect the battery, leave it 30-60 mins, then it's two clips and a plug to remove it. Dead easy.
How easy is the coding post stalk replacement ?
That's a pretty standard price, but yeah it is dear.
It was a £180 option in 2007.
2 minute job.
Yep, I've coded it on another members car - he did the stalk fitting. Coding was the easy bit.
The stalk came with a wire in the box, does this need wiring in or just the stalk replacing ?
What octy do you have? mkI, mkII?
MK 2 vRS Pre-FL 2.0 PD, controller p/n is a good un for cruise.
You may not need the wire.
Had stalk changed on warranty at main dealer. Got a print out Price was £125, supply and fit new stalk. So £175 just to fit is very steep
That is steep, I don't charge that to supply and fit.
