Typical MAF readings and boost pressure for standard CR170 ?
Possibly. Possibly not. Awful lot of traffic light Grand Prix tonight. I'll have a go at graphing it at the weekend to see if these are just instantaneous values or sustained (the phone was in the glove box to avoid me being distracted by it)
Cheers.
I think that figure must be erroneous.
In high enough gears, it takes long enough to progress through the rev range at WOT that I can afford a few glances at the MAF reading. Beyond say, 4000rpm I can see the value slowly reaches a peak of ~145 g/s and then slowly starts to tail off towards 5000rpm.
A MAF reading of 237g/s is so wayyyyyyyy out, I can only assume it's an anomaly...
I need to have a play with Torque's graphing too, not tried it yet, only done that with VCDS before.
You're absolutely right.
The recorded level is spiking when I turn off.
I've just recorded 153.1 peak on a longish journey, and it's spiked at 237.5 as I turned out off whilst sat still in Tesco's car park.
  • 6 months later...
Did a bit more logging yesterday and today, just wanted to remind myself of a few typical readings before my remap arrives.
And strangely, I can now get my MAF readings to peak around 152-153 g/s, which is now pretty similar to yours Gyp. Not sure why I was consistently in the mid 140s before.
Not sure, however as I didn't opt for the remap in the end, I'm happy to be the control.
Can you log save a log with this app like you can with dash command?
If you can then you can make pretty graphs :)
