Cree LED bulbs
Bought some Cree LED bulbs for my pre fl VRS TDi replaced the drivers side & tried it, lite up for a couple of seconds then went out, tried it a few times & same thing happened every time, put standard back in & now it keeps blowing the bulb, any ideas guys?
That will be the can-bus system cutting the power thinks bulb is blown because wattage is to low
They was ment to be can bus error free, will see what the seller has to say when they get bk to me.
Sorry didn't notice the last bit
Is it the main beam
Or parking lights and how many bulbs have blown
Is it the main beam
It's the parking lights (side lights) after removing the Cree LEDs it blew 3 standard 501 bulbs, off I went to halfrauds & bought a new pack, put it in & touch wood it's been ok since.
Glad to hear
I had 4w led bulbs fitted and the only way I could get them to work was to turn off the cold light diagnostics for parking lighs
Good to see you have sorted it. Best way I found was to leave the lights off after fitting for a while and then turn on but don't turn off straight afterwards as they don't like it
Sent from my Galaxy S5
Cree on sidelights? use normal smd leds with canbus system
