Having a nightmare
My speedo has just blew and now does not work at all meaning I can't start my car or anything, just went on eBay and bought a new speedo from the same car to the same criteria I have a few questions
How do I code the new speedo?
How do I change the mileage on the new (but used) speedo to math my existing?
I can program the keys it's just the speedo Im going to have trouble with, I inkw I need to get the skc pin so I have ordered vag tacho but what are the instructions to do this
Any help would be highly appreciated
Tom
Tom
You'll need VCDS
You'll need VCDS
More than that, IIRC normal VCDS cannot program the cluster/key for the coding.
There is a chap on here who does alot of key coding and should be able to advise.
edit: Actionman39
You'll need VCDS
I have that I'm just curious on how I would do it as I can't get the coding from the current speedo as its blew I will test it tomorrow to see if it gets any communication from it hopefully it does because then I can program the new speedo and get the immobiliser works again
edit: Actionman39
It's not the keys I need help coding I can do that and have done before, it's the speedo I need to code it to the ecu but I don't have the codes from my old one
Sorry i meant i think you need special software to pull the code from the dials. and the dials cant be changed
what are the chances of having the dials repaired?
Isn't it vagtacho?
Just swap the speedo from the replacement cluster into your old cluster, voila, no coding needed.
Also stop blowing up the cars electronics, you're a repeat offender now, just because you have a soldering iron and 'helping hands' does NOT mean you should be fannying around with the cars electrics.
It's always nice that there's a fellow Briskodian who is good at burning out electrics
That made me laugh.
no idea haha, i will sort it out eventually the cars off the road until i get insured anyways I'm not using it for uni so its not really a hassle
Isn't it vagtacho?
i think so thats what i have just bought anyways
got to learn one way or an other haha, practice makes perfect
i like this one hahaha
Yorkshire killed my electrics
But some people are happy at giving stuff a bash, even if it does go wrong. I accept that it may cost me twice, three times as much even than if I let a professional do it, but I want to learn and don't have anyone willing to teach, so who are you to tell anyone to stop?!?(with all due respect :p )
Did make me laugh too :giggle:
I'm all in favour of people 'having a go' actually. I was being 'tongue in cheek' so you were indeed supposed to laugh. I'll help anyone but I expect to be able to exact my payment by extracting the micturition.
Yeah I realised after hitting post that it was probably meant tongue in cheek and there's nothing wrong with extracting the urin, if it comes across as a joke or in a light-hearted manor ;)
What were you doing to break it? :p
just changing the SMD's to blue haha ordered a new one so i can try again
