Winter tyres error?
I have just ordered some winter tyres for my Citigo Sport, however in error I have discovered that they are Extra Load Tyres. The speed and load rating are higher than the current ones as well. Should I send these back to the supplier or will they be ok?
Of course they'll be ok, they're rated to go to a higher top speed and take extra weight.
So long as they're not lower it doesn't matter.
Brilliant thanks!
Sidewalls will be stiffer so there will be a slightly firmer ride and marginally better handling. Whether you will actually notice this though is questionable.
Being extra load tyres, you may need to run different pressures.
