Do I need a new Cent. Elec. Controler
Got home tonight, took ignition key out and radio did not switch off. Press lock on remote to lock doors and nothing. Doors lock ok with key or button on center console, electric windows work ok then did a scan with vagcom
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: TMBBT21Z7B201xxxxxx
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AG    HW: 03L 906 023 AG
   Component: 1,6l R4 CR td H23 6930
   Revision: --------    Serial number:
   Coding: 00114016032500080000
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_ECM16TDI02103L906023AG 003003
   VCID: 6BDFD975829ED11
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0105
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 73430 790 00999
   VCID: 7BFFE9353AFE411
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_Climatronic_SK35.rod
   VCID: 820114D11514B09
Address 09: Cent. Elect.
Cannot be reached
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66631017901647
   Coding: 100001
   VCID: 40855ED9D398E29
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC1YKNYV
   Coding: 0020788
   VCID: 3D7B272D646A8F1
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   009 0136
   Revision: FF010037    Serial number: 20100718100662
   Coding: 5080140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS_SK35.rod
   VCID: 77F7F505CED6651
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 903 M    HW: 1Z0 920 903 M
   Component: KOMBI         H04 0405
   Serial number: 00000000000000
   Coding: 410D00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 3F875D25A6669D1
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 270610F2000104
   Coding: E9A07F0640020200001303
   VCID: EDDB576DF48A5F1
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0405
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SK35.rod
   VCID: EAD15C710D64489
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 B    HW: 3T0 035 680 A
   Component: RNS-MID       H11 4024
   Revision: AB001001    Serial number: SKZ6Z7Q8585209
   Coding: 04010400000100020000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: ------------------------- ------
   VCID: 2F670D657E066D1
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0000758
   VCID: 76E9F80101DC1C9
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 31630B1DA8327B1
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000758
   VCID: 489546F93BA8DA9
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 32610411AD34409
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336F0115522E491
End   ---------------------------------------------------------------------
Edited by mannyo
Remove VIN as its not a good idea to publicise it.
Check for water ingress is the first thing, if water has got on the wiring of the controller then it causes all kinds of issues. Locate the controller and check for dampness, perhaps even disconnect, check the connectors for dampness (any green gunge) and if non reconnect.
The controller must be functioning otherwise your windows and central locking would not work at all, these are all controlled directly from the controller.
The only symptom present at the moment is that its lost comunication on the canbus, without that the car is not going to lock on the remote because its not getting the signal from the key to say "lock please"
Thanks mannyo. Is the controller behind the panel under the steering wheel
I'm not sure on the location on the MK2, might be worth sending a PM to Eddie-NL to ask location.
it is in the drivers footwell
remove the felt footwell trim, look up
it has 3x large plugs
Cheers Eddie will have a look
Finally got round to checking controller connectors, all seem fine no sign of water/damp anywhere. Found another problem. If the headlights are on and I turn ignition off they change to sidelights as normal but when I take the key out of ignition sidelights remain on usually all would go off. Could it be the ignition switch
After disconnecting battery for 5min I am now able to conect to 09 controller, here is the scan
Chassis Type: 7N0
VIN: TMBBT21Z7B2019886
Readiness: 1110 1000
   Revision: 00H35001
   Coding: 0017665
   Revision: 00005001
   Coding: 0000000002
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40180AB8E05BB1C040100080150081E4446000AE727D81605C8400000040
   Shop #: WSC 26041 576 84148
   VCID: 387536398B48AA9
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 21071  22  0601
   Coding: 00DFB7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 300610 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 146
                    Mileage: 103269 km
                    Time Indication: 0
                    Date: 2111.14.11
                    Time: 14:03:50
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 100001
   Coding: 0020788
   Coding: 5080140000
   Coding: 410D00
   Coding: 000000
   Coding: 0000758
   Revision: 00H17000
   Coding: 0000758
   Coding: 0000144
   Coding: 0000144
The fault displayed is probably just the fuse. It is common for the headlight washers to freeze to the bumper and blow the fuse. Probably not the cause of your other faults.
Yes I removed the fuse, got fed up of it using my washer fluid
