Alloys from Demon Tweaks.
When ordering alloys do you have to specify the quantity of 4? So say new team dynamics would be 1k!? Or is it 1 set of 4 so say £450 or thereabouts? Also what is the most common size to get 17s for the Fabia vRS? ET etc probably running the usual 205/40/17 tyres.
Lots of noob questions [emoji31]
They are a 'Set of 4'
& you might better the Demon Tweaks price elsewhere.
http://alloywheels.com
However I think their database has errors (not only theirs TBH) since they publish different wheel fitments for the Rapid & Toledo (so one is definitely wrong - they are the same car) make sure you're certain of the size, PCD, Offset and Center bore before ordering.
Skoda fitment are showing correct. You will find often errors on conversion charts etc. Different and wrong spec. Many companies and suppliers will repeat the same error due to the source of info being the same.
you certainly can buy wheels singularly for some of the better brands like BBS or Ronal because I have on occasion bought singles to replace duff ones, but I would normally assume it comes as a set of 4 unless stated otherwise
TD's at Tweeks are as a set of four, also if you ask them for tyres you will get a free four wheel alignment, I did when I got the wheels for the Golf.
 Good bunch of lads and worth a trip over to see them if you live local enough.
I've only ever used demon tweeks for mail order, and their service is normally spot on, too far away for me to pop in.
Try rimstyle alloys
Bought 2 sets from there.
+1 for rimstyle
Thanks for the suggestions, I live in Scotland so a bit far to pop down!
Rimstyle don't do TD's in gold for the fabia [emoji17]
I buy from DT as well...............................way too far to travel........................& most are sets of 4...........read the small print or speak to them directly.............
