Loud Buzz From Scuttle Pannel - Bang/ticking from speakers
Yesterday I had a bit of a weird problem.
I was servicing the Octavia, so had it parked, unlocked, windows down, bonnet up and the radio on without the keys in the ignition.
I lent in to turn the radio up, as soon as I touched the volume, it went dead. First there was a very loud thud from all of the speakers, and then they had a rhythmic click every few seconds.
Under the bonnet there was a high pitch buzzing noise appearing to come from under the scuttle panel.
No amount of attempting to turn the radio off, cycling the ignition, locking and unlocking or anything stopped it.
Removing the negative battery lead, it still carried on for around 5 seconds but eventually stopped.
I reconnected the battery after around a minute and everything appeared to be normal.
It did this once before when driving. I'd started the car, reversed out of a space and adjusting the radio caused the thud and ticking. I didn't get under the bonnet and hear the buzz as that time cycling the ignition stopped it.
I even did a scan yesterday after it happened as I had VCDS cable on me, and it showed up nothing that would suggest what it is.
I had the headlights out at the time so the light errors I assume are nothing to do with this.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000003431117
   Coding: C18A1F031004140000110D000000000000097F075C
   Shop #: WSC 25043 576 17493
   VCID: 3A7EAE537560C8CE959-806F
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 25043
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00471077
   Shop #: WSC 25043
5 Faults Found:
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to Ground
01497 - Bulb for Blinkers; Front Right (M7)
            012 - Electrical Fault in Circuit - Intermittent
01493 - Bulb for Blinkers; Front Left (M5)
00979 - Lamp for Low Beam; Right (M31)
            010 - Open or Short to Plus
00978 - Lamp for Low Beam; Left (M29)
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 941 D
   Component: KOMBIINSTRUMENT VD1 0918
   Coding: 0007401
   Shop #: WSC 24000 186 85313
   VCID: 387AB45B4B6CDADE63D-806D
No fault code found.
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010560780C5
   Coding: 3F3F0740072303
   Shop #: WSC 73430 790 00000
   VCID: 2A5E9E1385C0784EE59-807F
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 18D002407F2D8505485F861004CC
   VCID: 79FC715F30E603D6DC3-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
2 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
            000 - -
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       012 0023
   Revision: 00012000    Serial number: SKZ7Z3E0024338
   Coding: 0000402
   VCID: 2D54950FB42E6F7600B-8078
Yup.
Had this on the Stream a few times.
Could be just driving along it would just freeze and make funny noises.
Or it would randomly make really loud popping noises or the volume would go mega loud for a split second. Used to make me jump out of my skin.
It seems its common on the Stream and I have heard tales of the dealers having a software update for it to cure this problem.
Phil
Did it ever have a buzz/squeal from under the scuttle panel?
That was the most alarming bit.
I wish I'd recorded it now but my main concern was stopping it at the time.
Not that I ever heard.
But it always happened when we were driving so may just not have been able to hear it.
Phil
