Wiring
Anyone know any common places for wiring to break for interior lights on a fabia vrs mk1?
Still no joy?
No doing my head in now mate all fuses ok bulbs ok switches working fine I've tried a secondhand convenience module but the central locking then stopped working so I've put my original module back in for now I've check and traced the wiring to and from the interior lights I'm thinking it's either the door modules or the ccm it's really driving me mad now don't realise how much you need an interior light until it doesn't work usually a simple task of replacing a fuse or bulb but no apparently interior bulbs have to be powered by modules these days it's a joke lol
 I know this might annoy you but are you absolutely sure you've checked the right fuse? Fuse number 4 (10 amp)?
Are interior lights completely dead?
The door triggers interior lights as well as being manually switched on/off on unit itself (as you know).
Check wiring from fuse to light itself for connectivity with a volt meter.
If all else fails, you will need a car electrical check-out from a garage with their test equipment to stop further second guessing..
Sorry, of no real help here..
TMB - I've even replaced I'm that sure lol bit more playing with it last night I found that plug xp2 on the bcu the brown plug has 3 wires to it and there all live I believe this is the power for the interior lights surely it should have an earth out of there aswell
Giandougl - none of them work at all no matter what setting there on I've even unplugged them and powered them up with a probe they all work then I've even probed the roof lining light on each setting that works fine aswell I've checked continuity at each end of the wires I.e roof lining wiring to each door and boot light all fine this is why I can't understand why there not working
