Clutch pedal problems
Hi,
 Ive just purchased a 2010 Skoda Superb estate , have  a problem  with the clutch pedal , in that it keeps sticking , if i pump the pedal it seems to sort it for a short time ,but after a time it sticks again , is it a simple fix or does it need a master clutch  cylinder if so is this a big job?
hello,
       have same problem,comes and goes. is this a known problem.??
I had a similar problem on my Seat Leon MK I some years ago. On a couple of occasions the clutch pedal traveled to the floor under pressure but then did not rise back up again and I had to use my foot to lever it back up.  The clutch master cylinder was shot and a replacement fixed it.
  • 7 months later...
Hi JKM,I have the same problem,and was wondering if you found the answer,and is it resolved,Frankie.
