body control module cost
hi all i have a 59 plate and the bcm has gone wrong how much am i looking at
If you have AA breakdown repair cover then nothing
If not then best part of 400 supply and fit, that's what I was charged on a pre fl from a independent skoda specialist
I can get the BCMs, can also fit it
AA breakdown repair cover hows that work then mate
Basicly you have normal aa cover with extra's e.g relay which is recovery anywhere in the UK
Stay mobile which is courtsy car while your car is in the garage
Breakdown repair cover when ur car brakes down if AA cannot repair the car at the road side they will recover it to either an AA approved garage or a VAT registered garage off your choice
Once the fault is diagnosed the garage ring aa tell them the fault once aa approve the work then the garage will fix the car and all you pay is £35 excess
Cost about £22 a month and AA contrabute up to £500 in repairs if it's more then u have to add the diffrence
Edit : only pay for not wear an tear parts shows a list in your starter pack
modules aren't expensive if bought second hand from a breakers or Ebay. You just have to but matching part number to your original. They're easy to fit & will probably only need some minor coding to match your car
