Radio install help
I've just received my new Android double din unit, but I need help installing the radio connectors. The Bolero has two cables going to a Fakra connector and the Android unit, has two single Fakra connectors, but I can't get them to mate.
Is there any adaptor that I need?
When I installed my previous one in my Leon, it only needed the one connection, but I've tried that and the reception is poor.
Sent from my Nexus 5 using Tapatalk
Edited by bubba
you need to buy an aerial adapter which is designed for a powered aerial. All this is in the oem headunit but people like autoleads make the adapters needed
Thanks I'll have a look
Can't seem to find anything listed for mine, only go up to a 2008 and it's the won't type.
Solved, took the clip apart and it fitted straight in
