Lost Keys
i have a octavia sdi with no keys i have access to another sdi for parts just seeing what needs changed. i rrad that the ignition lock, ecu and instrument pannel needs replaced is this everything or are there any other modules needing changed too.
cheers
if the engine etc is the same & all the part numbers for ECU etc match then yes you can use the ECU, clocks, ignition barrel, key & also the door locks. Then once fitted it will start up
Thanks for that
