Help With Coming Home/leaving Home Lights.
I have a 2008 pre FL VRS with Xenons and Maxidot.  On Maxidot there is no option for switching it on and I don't have auto lights. Is it possible to do ? Does it need VCDS to activate it?  Thanks in advance.
Yes..It can be activated with VCDS on a Pre FL car...not Post FL without light sensors though
Nice one. I just need to find someone with VCDS on the isle of Wight now....
On a pre FL the lights have to be left on for this feature to work ( non auto lghts )
Do you have auto wipers?
As it is a vrs I suspect not, but if you did it is relatively easy to fit a new switch to give you auto lights.
No, I don't have auto wipers.
Is that after the VCDS activation?
Yes.
It basically works on a timer system (set with VCDS).
Cheers .
I've got it activated on mine you need to leave the headlights on.Turn off car, lock and the lights will stay on for the programmed time.
