Winter Wheels/tyres Advice?
Anyone know of any good sources for winter wheels/tyres for my VRS? I've found these on eBay http://www.ebay.co.uk/itm/261664594900
yesterday and I think they should fit. Any advice?
They look in good nick and the guy says they fit, should get my wife through the 'potential' snow?
If you check with a tyre calculator,  the tyres supplied (195/60 15) are taller than standard VRS ones (24mm in diameter or 4%). Your speedo and milometer will be out. However this has an advantage in snow as you will get more ground clearance. You ideally need 55 profile. (195/55 15).
Is it for a Fabia or Octavia, as I see your profile shows an Octavia, but you've posted in the Fabia forum. Those are the wrong size for both.
You can get complete wheels (and I've done so in the past) from http://www.mytyres.co.uk/Steel_wheels.html
