Led number plate bulb
having replaced the number plate bulb for Led's I know have a dash light on .
Question is how do I turn of the warning light or have I got the wrong type bulbs in,
Make sure you have "error-free" canbus bulbs,
and code it with VCDS. ( "tell" the car you've got LED)
I bought these and they work perfectly with no errors....
N um skull did you still have to code it with vcds
Nope, they work fine.
I have the same bulbs, and got a warning... And it disappeared after VCDS-coding
Num skull is yours a fl or pre fl superb
Pre FL...
I thought the numberplate bulbs couldn't be replaced by LEDs without a load of hassle in a preFL car? Sure that was the consensus on the LED bulb threads.
Im also having problems changing to LED bulbs, dont want to seem thick, but whats vcds-coding?
With VCDS-coding, you can hook up the car to a computer with a cable and change different things in the electrical system. You can also check the car for faults and run diagnostics stats.
