does anyone know how to reset the service interval msg ?
superb 2009 3.6
is there a way to make that annoying "Service now" msg when starting the ignition go away ? without going the dealer i mean...
Yes, it is detailed in the manual.
Be aware though that if you reset it manually the car will revert back to fixed service intervals i.e. 10,000 miles or 12 months, whichever is reached first.
If you are currently on variable / long life servicing and want this to remain then you'll either need a dealer or friendly member on here with VCDS.
Resetting Service Interval Display
It is only possible to reset the Service Interval Display, if a service message or at least a pre-warning is shown on the display of the instrument cluster.
We recommend having this resetting performed by a specialist garage.
The specialist garage:
● resets the memory of the display after the appropriate inspection,
● makes an entry in the Service schedule,
● affix the sticker with the entry of the following service interval to the side of the dash panel on the driver's side.
Reset the service interval displays by using the reset button 7 ⇒ page 10 on the trip counter.
On vehicles which are equipped with an information display, you can call up this display in the menu Settings ⇒ page 19.
CAUTION
We recommend that you do not reset the Service Interval Display yourself otherwise this can result in the service interval display being incorrectly set, which may  also result in problems with operation of your vehicle.
Note
● Never reset the display between service intervals otherwise this may result in incorrect readouts.
● information is retained in the Service Interval Display also after the battery of the vehicle is disconnected.
● If the instrument cluster is exchanged after a repair, the correct values must be entered in the counter for the Service Interval Display. This work is carried out
● The data displayed is the same after resetting the display with flexible service intervals (QG1) is displayed as that for a vehicle with fixed service intervals (QG2).
We therefore recommend having the Service Interval Display reset only by an authorised ŠKODA Service Partner who is familiar with the procedure for resetting the display with a vehicle system tester.
● Please refer to the brochure Service schedule for extensive information about the service intervals.
superb 2009 3.6
get the car serviced? :)
You don't need Maxidot or the steering wheel controls.
"Reset the service interval displays by using the reset button 7 ⇒ page 10 on the trip counter."
Download the manual here, be sure to select the correct year of your Superb...
http://new.skoda-auto.com/en/mini-apps/owners-manuals/superb
You need 'button No.7' which is marked '0.0' and is next to the speedo. All Superb's have this button.
got it :)
thanks a lot
another question please, im trying to adjust the seat and save it onto its memory, doesnt work
the manual says, adjust the seat, then press SET, then within 10 seconds i should press one of the number and a confirmation sound should play, nothing happens , it does not save it, and no sound or anything :/
Have you turned on the ignition before setting seats?
