Climate Control isnt well
Hi, i have a ocatvia mk2, its a 2007 plate with climatic control. Its been playing up for about a year. In auto mode , initially after 45 mins or so the air stopped coming out the vents, the fan was still running just nothing coming out anywhere, even if you manually opted for a direction, you got heehaw. More recently that has changed to about 30 mins running time before it gives up. If I turn it off for about 5 mins it will start working again. I have discovered that if you select the econ button it works fine, albeit with no air con. Its been into skoda for 2 days and i got it back washed, hoovered and told that it was working fine!
Does anybody have any idea what wrong with it?
  • 2 months later...
Hi,
all sorted now. Evap temp sensor was giving incorrect info causing the evaporator to freeze. 26 quid from skoda and a 30 minute job.
cheers Keith
