Remapped diesels with black smoke?
Hey there,
Is it normal for a remapped ( stage 1 ) diesel car with the dpf removed and a completely straight through exhaust to expel black smoke on hard acceleration?
I always thought it was normal but my friend told me that it shouldn't happen and it means the car is over fueling and I should go back to the mapper for a tweak.
I will add it isn't like a smoke cloud nor does it stain my car however it's enough to see a stream of smoke on full hard acceleration.
Also my injector seals need replacing which are getting done in Jan which could also add the smoke.
Just wondered on everyone views/comments?
Car is always maintained and serviced correctly.
Thanks.
A small amount is normal/acceptable.
If it's a lot or a constant stream then it's not normal.
Black smoke is unburnt diesel so some is normal if you put your foot down in a higher gear as the car has to inject more fuel and wait for turbo to spool etc.
Phil
Accelerate hard in most non-DPF equipped diesels and they will smoke.
Add a remap to that and there will be more smoke.
If the car is high mileage or generally getting on a bit add more smoke.
If you have worn injector seals then add even more smoke.
My 2002 factory standard BMW 320d would leave a black soot trail on the tarmac if booted hard after a prolonged motorway cruise!
Here is a vRS with a DPF delete and stage one remap. Check out the soot on the rear bumper and tailgate...
Some cars are better / worse than others. Yours sounds normal to me.
