Vrs Clutch creep, shim kit?
Hi recently I've had clutch creep in first and reverse. And sometimes it's difficult to disengage 1st or reverse. I've heard about the main shaft shim kit like this
http://forums.vwvortex.com/showthread.php?6089802-02M-whining-decel-noises-aftermarket-clutch-disengagement-issues-mainshaft-axial-play but would that solve the problem or would I need something like this and is this for the right gearbox for a vrs http://forums.vwvortex.com/showthread.php?5699167-NLS-02M-clutch-shim-kit-now-for-sale! Thanks.
First link is what I've seen used,someone did it about a month ago if you have a search :)
I did it. Cured my problem. Was doing the same. Very easy to do psrts coz me about £7
Which did you do? The gearbox shim or slave cylinder shim and where from?
GeeMan is the one to speak to about this,
Gearbox shim. What the video mate. Helps loads
Where did you get yours from for £7
Tps
