Brake upgrade choices
I'm running porsche 993 turbo (aka big reds) fronts but needed a 3mm spacer to fit avus s3 17" alloys with cupra r 323mm discs and ds2500 pads with braided lines and ATE super blue fluid and they are awesome.
More important than calipers, imho
Would you say I'm better off keeping the original calipers an change my pads?
There's a set of calipers off a porsche 966 turbo but the model numbers don't seem to match the ones that fit my octavia can anyone shed any light on these please
996-351 419
996-351 420
I can't seem to find any info on these calipers but there red an he says there off a porsche 966
http://m.ebay.co.uk/itm/321617190352?nav=SEARCH
Don't suppose u know the model number for these calipers?
Are spacers ok to use?
that depends on how far off what you want you got
I'd rate red stuff as being 25-50% less effective than the OEM Mintex/Pagid pads
A Pad like a DS2500 is circa 25+% more effective than OEM Mintex/Pagid pads
If you do go for uprated calipers, just don't knobble them by putting crap pads like red stuff in them
Thanks for your help
I've been looking at compbrakes rather then the porsche route anyone used these before?
U get the full brake upgrade kit
Edited by Dans..vrs....octavia
No - avoid
My compbrake 6pots split open from the bleed nipple after 2/3yrs use
Boxter calipers is what u need to search on ebay
Then check numbers :)
Rather than search the numbers
There's a set on eBay with the number
986 351 421 03
986 351 422 03
Can anyone tell me what the 03 means an if these will fit because all the number seems good just the 03 im not sure of
986 351 421 03
986 351 422 03
Please can someone help this is getting frustrating :-(
http://m.ebay.co.uk/itm/151523163796?nav=SEARCH
There's a set of Porsche calipers on eBay with the right model number but they are black can anyone confirm if these will fit or not please? An where I could get an adapter for these?
Daniel
Peeeeeeeeete :D
Dan see my post on the previous page. Those are the part numbers you need.
Picked up a new set of calipers today :-) with the numbers U stated on the first page just need some adapters now but making progress
Vagbremtecnique or such did petes iirc
How do I get hold of them it says there website is comin soon?
Thanks for everyone's help an input
Eeeeerm
Creation motorsport do some too, for assorted calipers
Pete may have vagbrem number tho
Hi Dan I've sent you Vagbremtechnic's contact details. Cheers Pete.
