Fault Codes
Fault code showing up again! I've had an ongoing problem with my car. It goes into limp mode but when I turn it off & on again but car regains power again.... Any suggestions? Please?
Photo attached
Can't see the photo, what is the code number?
The fault code showing is: 17965
Thanks!
Probly best to start off by checking the hoses, is there anyway to check if there is a boost leak?
Smoke test or a quick listen
Thanks. I will start to investigate and see if I can get anywhere.... *fingers crossed*
check the rubber hose from the black vacuum block on the inner wing to the turbo wastegate
whats your mileage?
another possibilty is air mass meter
Thanks for the tip! I will get the other half to check that out for me
Mileage is about 85 thousand on the clock! Need to get the timing belt done on it very soon!
Air mass meter?
the air mass meter is a sensor just after the air filter, it measures the volume of air going into the engine to allow the ECU to work out the exact amount of fuel required by the engine for the load
it works in conjunction with a air pressure and air temperature sensors on the outlet of the intercooler
you can get a recon air mass meter ( MAF sensor)  from skoda, their are other options, they are not cheap, about £100 for a recon and £300 for a new, so normally last thing to check
symptom of them going is normally get to about 2500-3000rpm  then loss of power / limp mode and flashing coil on dash,
problem with wastegate / turbo is similar but more dependant on amount of right foot applied
check the rubber pipe first as that is only about £30-£35 to fix, it is easier to see from under the car,
if it is a stuck / sticky waste gate on the turbo, some have used a "mr muscle" fix to clear the carbon build up and free the wastegate
Edited by bluecar1
