EML flashing - car juddering
Hey all,
I've seen some old posts about this, but thought I'd check:
05 plate 2.0 petrol Octavia 4x4
Just driving along, car loses power under acceleration, judders a bit, EML light flashes. If you release the go pedal, it stops, ok for a while, then may happen again.
There seem to be various potential reasons for this - coil packs, coke build up etc. Seeing as this has just started, how long can I expect the car to work before it goes into limp home?
Is it worth giving it a bit of a thrash with engine cleaner in the fuel? Will the ECU tell me what the problem is if get a diagnostic laptop plugged in?
Cheers all.
Edited by FuzzyLogic
Hey all,
Cheers all.
When was your fuel filter last changed?
Most likely a coil pack but get it scanned to be sure.
Thanks for the replies. I will get it diagnosed - will skoda still replace the coilpacks for free d'you think?
Answer: no. The car was not part of the coilpack recall.
I was told this morning that a flashing engine management light means misfire on one (or more) of the cylinders.
Error code will most likely be something like P0304 - http://wiki.ross-tech.com/wiki/index.php/16688/P0304/000772 but you need to get it scanned first and go from there.
Yep, it was plugged in today, misfire on cylinder 3. Also there's been a persistent leak, turns out it was a warped oil filter housing. So, going in on friday for coilpack and the other.
