Front turn signal stays on
I have a 2013 pre-FL Superb estate and tonight when I got home the left front turn signal stayed lit after I turned off the lights.  I had to remove the bulb so that the battery would not run down overnight.  I installed a HID kit from Londoncolour, non-canbus, last week and coded it via VCDS according to instructions here on the forum and it is working perfectly, no errors.  I mounted the ballasts inside the lights but I can´t see that they have damaged the wires or connections to the turn signal bulb.  Anyone have any ideas what is going on with the lights and if the HID kit could be causing this?
Thanks in advance
Biggi in Iceland
There have been people with this issue caused by a faulty BCM, but I think this was on an Octavia rather than a Superb.
Thanks for the quick replies guys.  Any ideas what went wrong and how to fix it?  I changed the coding in Central Electric 09, byte 14 bit 4 from 0 to 1, but didn't change anything else.  Should I have changed bit 3 as well?  What about using the "Auto" setting on the light switch, would that cause this fault?
Any ideas on where to get a replacement module and how hard is it to replace?
Biggi
Biggi
Basically its broke, you need a new one.  If you are good with electronics you could try opening it up but you're in chainsaw juggling territory.
I have no intention of trying to fix the module, no skills ;-)  Just wondering what caused the failure in the first place, so that I can prevent it from happening again if I reinstall the HIDs
Why are you looking at trying to fix it. It is a 2013 model therefore let the Skoda garage deal with it or have I read your article incorrectly.
I'll try to get it fixed under warranty, have already removed the HIDs, but I really like them and would like to reinstall if I can be sure that they won't blow the BCM module again
From what I have read it may well be unrelated to fitting the hids and just seems to be a failure of the BCM.
I got 2 BCM's fried because I've "upgraded" my lights to aftermarket HID's - both were replaced by dealer under warranty but now I know it was the fact that HID's were installed.  Have you ordered 35W HID kit or 55W kit ?
I'm still very tempted to get 35W kit as previous one was 55W - but if you had a problem with 35W I wont chance it and I will just stay with Nightbreakers.
Canbus or non canbus kits?
55W HID kits are not recommended for this very reason.
Always go for 35W.
I've been running a non-CANBUS 35W H7 4300K HID kit from London Colour (with the car coded) successfully now for 50,000 miles, most of which with the dipped headlights turned on without issue.
Edited by silver1011
That's what I thought.  The question remains - what is the correct coding?
Exactly what did you change in terms of the coding?
I only changed bit 4 in byte 14 from 0 to 1.  I did not change anything else and kept my light switch set to Auto
@bb429 - did you got that BCM replaced under warranty ? And do you know which BCM do you have (vag number in VCDS)
@silver1011 - which BCM do you have ? I have 1k0 937 087 p
I will wait until my NCT (MOT equivalent in UK) which I have in FEB and then I'm going to chance those 35W Londoncolour ones.
Sorry I don't have VCDS, I had a friendly member local to me code my car.
Good luck, I'm 99% sure a 35W kit will prevent future issues.
I have the 1K0 937 087 AE module, it has been replaced with a new one.  The question remains, should I try the HID´s again and risk frying the BCM?
As mentioned, ditch the 55W kit, buy a 35W kit from London Colour and all should be good.
This can also be the actual stalk causing this.
I have the 35W kit from London colour, http://www.ebay.com/...=STRK:MEBIDX:IT
'Scuse my ignorance, but how would I go about fitting one of these? Are they just plug and play into the existing fitting, with the igniter tucked behind?
Edit: don't worry - I just found a DIY guide on YouTube, featuring a young lady wearing marigolds... Looks simple enough.
Sorry to go OT.
Edited by JakeBlade
