Need some help
Hi everyone, i just need some help regarding my fabia vrs i read a topic on here which answered my question a while ago but i can't seem to find it so if anyone be able to guide me to it that would be great
I changed the clutch and flywheel on the car and cars all fine except for the battery light flickers, traction light comes on and off and the rear demister does not work?
I read somewhere that there is a plug, sensor or wire that commonly gets broken off when doing a clutch change and that is the cause of everything, now i need to know what that wire or sensor is so i can get it sorted and changed
Thanks in advance
Try searching alternator load sensor wire, there's loads of topics and info on it. However it might not be your problem but it's a good place to start
Its best to get car on ramps. Take undertray of if it has one. The broken connection is to the right of engine.
You should see it right away. I managed to solda the wires together then put black tape round it.works fine now
This was main reason my traction control light was coming on after 20mins driving and staying on.
Hope you get it fixed
I try this out over the weekend, Anyone else with other suggestions?
I went to dealers and bought up a illustrated image of the gearbox and all i could see on there was the reverse switch and distance sensor im sure the wire im looking for is on the gearbox?
Looks like this...
