Need help with some questions regarding MFSW Retrofit.
Hey Everyone!
Longtime reader, first time poster.
I have a Skoda Octavia 1,4 TSi Greentech (11/2011). I've spend weeks, almost months trying to pull this off on my car, but with very confusing results, mostly due to wrong parts and mixing, what's nearing months of reading myself senseless to the point where everything starts to sound alike, thus me coming here, in the humble hopes of someone able to steer me in the right direction of a solution if possible.
I've bought the:
Maxidot display.
MFSW with the Roller buttons (can't remember the actual part number, but I'll add it once I get the chance to write it down the next time in my garage).
AirBag Loom for the new Steering Wheel (5K0 971 584 IIRC).
I've done a recent Auto-Scan, everything is included in it, except the steering wheel.
Now my main question, and hopefully the solution, is, can I exchange my current Clockspring module with the newer 5K0953569AL without having to replace the arms as well and thus be able to get the MFSW working? That said, I've been trying to get it working with my current, which is a 5K0953521BL.Replacing only the Clockspring instead of the entire Steering Column Stalk. Seeing as my old is a Low-Midline, and the newer Superseded **** Spring has become a Highline. More importantly, is there anything I've missed specifically, in regards to parts, coding, throwing salt rocks over my left shoulder? ;)
Note: 19-CAN Gateway; is corrected. But it's not related to my current predicament. Was feeling MacGuyverish for a few days.
--------------------------------------------------------------------- Start Auto Scan
Friday,09,January,2015,03:02:27:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: TMBCJ61ZXC2066204   License Plate:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 69 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAXA)       Labels: 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 CL    HW: 03C 906 016 CL
   Component: 1.4l R4/4V TS H15 0914
   Revision: L5H15---    Serial number:
   Coding: 00190012002401000000
   Shop #: WSC 73430 031 00066
   ASAM Dataset: EV_ECM14TFS01103C906016CL 001004
   ROD: EV_ECM14TFS01103C906016CL.rod
   VCID: 6BD5212782702B46511-803E
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 113B201C09280000880D04E4901D0050350000
   Shop #: WSC 41494 001 1048576
   VCID: 7BF51167FA10BBC6C11-802E
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000003
   Shop #: WSC 73430 790 00066
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7DF11F7FEC04B5F6FF5-8028
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 40000AB8A00508C040100080510081E4437800AE426D8D605C84C7000041
   VCID: 3F8DA577AE8867E6AD9-806A
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 23091  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 160911 05  54  0403
   Coding: 0730ED
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2T0V2R
   Coding: 0020790
   VCID: 3D71DF7F648475F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME6264537AE
   Subsystem 2 - Serial number: 6342MSME626449058
   Subsystem 3 - Serial number: 6351HSME29162E6CJ
   Subsystem 4 - Serial number: 6361HSME287C146CK
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110921200104
   Coding: 5080144000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 77FD0D57CE389FA6A59-8022
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 843 Q    HW: 1Z0 920 843 Q
   Component: KOMBI         H05 0607
   Serial number: 00000000000000
   Coding: 110A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 4683B093F952362EEEF-8013
Address 19: CAN Gateway
Cannot be reached
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2119
   Coding: 0131316
   VCID: 489FBEAB3B46205E1C3-801D
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revision: 00H20000
   VCID: 3467FA5B57CEB4BE40B-8061
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0131316
   VCID: 479DBD9736582F26159-8012
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         009 0081
   Revision: 0I001001    Serial number: SKZ1Z2L9083838
   Coding: 050004000001
   VCID: 3169F34F68DC81962BD-8064
1 Fault Found:
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 64731 km
                    Time Indication: 0
                    Date: 2023.14.24
                    Time: 22:01:43
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 1620
   Serial number: 130911F2001448
   Coding: 032B7864
   VCID: F1E9B34F285C4196EBD-80A4
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0131216
   Shop #: WSC 73430 790 1012546
   VCID: 326BFC43ADDABA8E527-8067
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00000152859350
   Coding: 0100000100000000
   VCID: 306FF64B63D6889E243-8065
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0131216
   VCID: 3365F94752C0B386591-8066
End   ---------------------------------------------------------------------
I'd seriously appreciate any help and info, that anyone can provide. As this has started to affect my daily routine. >_<
/John
  • 3 years later...
Hello :)
I know this is a very old thread, but how did you manage to exchange your old instrument cluster, with the newer maxidot ?
It would have required some coding ? Or ?
