Help rattle/rubbing noise after cambelt change
Hey guys as it says I got this rattle/rubbing noise and u can't for the life off me find it.
I've put my hand all the way down the timing covers and I can't feel anything rubbing it.
The belt was fitted with a total kit and water pump. I hope it's not serious :/
Check coolant hoses, sometimes they get in the way following a TB job and are rubbed by the belts. Had that on my Mk1 RIP.
Thanks for the reply had it looked at its the chain in the head making a faint noise
i once had the same problem , it was a faulty bearing in the new timing belt kit , as it was fitted by skoda dealer it was covered under their warranty so no further cost to me the whole lot got replaced .
The tensioner role has a spacer.did you put it back?
Edited by IulianE
